Free - SteamPunk Googles
mrsparkymrsparky Posts: 249
edited December 1969 in Freebies
Inspired by the work of the etsy artist Ambassadormann, this rather nifty pair of highly detailed googles is perfect for your SteamPunk aviators. Powered by a small steam engine, it can turn a series of cogs to drive a set of lenses that has so much magnifaction, you can see up a Scotmans kilt while standing on the Isle of Wight.*
The vacum tubes can illuminate the target cross-hairs which means you'll never miss a low flying haggis again. Plus theres no rear head strap, so it'll fit under hair and hats better.
Set contains a model on poser prop format, so it'll work on any figure with a slight tweak of the parameter dials. It also has a set starter textures, which for best results should be replaced with app specfic shaders like in the images below.
Renders 1 & 3, custom Reality. Render 2 - P6 with WD's 120 Materials Vol2.
* Note: Only when it's not raining in the UK.
Download from: http://www.sparkyworld.co.uk/3d10own.htm
  • cimairacimaira Posts: 0
    These look very cool!! Thank you so much :)
  • mrsparkymrsparky Posts: 249
    Thanks cimaira!
    As remarked at rendo, this is gonna the last freebie for a couple of weeks. Just starting on a new project that will be blending a mix of 3D freebies, photography and tutorials. Some of which I'll be asking the community for help on.
    Particularly here for some daz studio stuff.
  • katfeetekatfeete Posts: 255
    Or as we say in the US, "once in a blue moon." :D
    Thanks for this -- i've been looking for something like them for a while now. Your freebies are always wonderful.
