Help Using Kids 4 Expressions.
I am having a difficult time applying the expressions and morphs to my K4 figures. If I like a particular expression or eye/mouth pose and try to apply it, nothing happens. Is there anything in particular I need to be doing besides double clicking or trying to drag it into the scene?
Similarly, can the K4 morphs be used on Genesis figures if you have the 'growing up' bundle?
Thanks in advance for your help!
Do you have your K4 figure selected when you try applying the morphs? If you don't have it selected, the morphs won't know what they are to be applied to.
Hi, thanks for answering :) Yes, I do have the K4 figure selected. it acts like it does something but the morph does not apply
Thanks for the additional info Jade. I totally forgot that some morph INJs just make those morphs "available", but you have to manually dial them up (or down) to what you actually want.
More than welcome. And I should Clarify the Select the figure part...
You only need to Select the Figure to inject the Morphs not any of the parts...
You need to select the correct part of the figure, the Head for example to Dial the Morph once it is injected. Not to inject just to use.
