Adding to Cart…
Thank you!
The lashes do look very good. However, I am having an issue with the product: The morph dials are not available, i.e. I cannot change the length or angle of the lashes, which is basically what I bought it for.
Any ideas what's going wrong?
The easiest way to find them is to select Genesis 8 Female (not the lashes) and search for VWLashes in the Parameter tab or the Shaping tab. See screen capture attached.
If you prefer to locate them manually, they should be located under Genesis 8 Female/Actor/Head/Face/Eyes/Real World/ If you don't find them in that location, please re-install the product.
Thank you for your support acquiring my product.
Thanks for the response (and sorry I did not get back sooner - I don't get any forum notifications for whatever reason). Unfortunately that is exactly what I tried, but still there are no controls. There simply are no VWxxx morphs anywhere. I've never had that before, no idea, what's going wrong ...
How did you intall it? Manually, using DIM, using Daz Central or Connect? Please, let me know to see if I can download it using the same method and verify if there are missing files. You can also try downloading and installing it using a different method that the one you originally used to install it.
The morphs dials data should be installed in these folders:
<The name of your content Library, ie My DAZ3D Library>\data\DAZ 3D\Genesis 8\Female\Morphs\Virtual_World\VWLashes
<The name of your content Library, ie My DAZ3D Library>\data\DAZ 3D\Genesis 8\Female Eyelashes\Morphs\Virtual_World\VWLashes
I also suggest you to open a support ticket with Daz just in case there is any issue with the installers (I don't have control over those apps).
Thanks again for your help! All good, it works now - it seems that there is/was an issue with the first project I tried it on. I had no problems with another project. Phew ... :)
I used the Install Manager, to answer your question. I did have several other issues with projects here and there over time, e.g. messed up shaders settings, rendering wouldn't work any more, etc. - not sure if it's me doing something wrong or if it's a bug in the application. But for now everything is fine. :)
I am very happy to know that you can use the product. It was a pleasure for me to try to help you. Happy renderings!
