Genesis Starter Essentials
Where can I get Genesis Starter Essentails? I have looked all over
but cannot find them. Any help would be great. Thanks
It ships with DAZ Studio. If you have DAZ Studio 4.5+ in your product library you will also have the Genesis Starter Essentials. The easiest way to get install it is to use the DAZ Install Manager to download and install it.
and given that a picture is worth a 1000 words, or something like that
Make sure you also install Genesis 2 Male and Female Starter Essentials. The easiest way is to install and find them is with using DIM.
...and if you're not using Poser, you won't need any of those which end with "PoserCF" (Poser Configuration/Poser Compatible Files). Of course, if you do want to use them in Poser, you also need DSON.
