Michael 4 content not loading?
sdkraemersdkraemer Posts: 14
Hi,
I am new to DAZ but think this might be a problem:
I got the Michael 4 content. In the library there are all types of facial morphs (See attached screenshot). When having the figure loaded and even marking the face area ... double clicking on the little pictures/'rc-merge into scene'... has no impact.
Nothing is chaning on the figure?!
Any help appreciated.
Stefan
  • Richard HaseltineRichard Haseltine Posts: 109,345
    Those load the morph data, if it isn't already loaded (if you have Power Loader active, that is if you get a dialogue when you load the base Michael 4 figure, then the morphs probably are loaded0. They don't set the morphs, however, just make them available for use.
  • sdkraemersdkraemer Posts: 14
    edited April 2014
    Yep, got it ... but it is not intuitive at start.
    Select body part where the morph has to be applied to
    Activate the morph (pic)
    Parameters TAB provides the sliders
    Sometimes I am not knowing which body part needs to be selected before?
    Nevertheless DAZ 3D immerses me ;-)
    Post edited by sdkraemer on
  • JaderailJaderail Posts: 0
    None, as long as the figure is selected the morph file will load, you will then need to open the right body part in Parameters to use the Dial.
