Morph that makes G8Ms nose gone
in The Commons
Hi everyone,
does anyone know of a morph product for the G8 male figure that makes his nose completely flat and gone? So far, I have only found this product: https://www.daz3d.com/wicked-fantasy-morphs-for-genesis-3-male-s
It's exactly what I'm looking for, but sadly, it's only for G3. (Page 2 of the demo images shows the no-nose morph.)
Any help is greatly appriciated!
Bear in mind that if there is a no-node morph, it will work only with supported shapes. A morph moves the points that defin the shape along straight lines, so yes you could move the nose points to make a flat surface - but then any other shape applied thata ffected the nose would move the points away from the flat surface to some degree. A GeoGraft that actually hid the nose and patched the hole might work better - however, I'm not aware of products that will do the job at all (possibly because of the limitations).
This freebie has a no nose morph https://sharecg.com/v/94004/gallery/21/DAZ-Studio/InTheFlesh-Merchant-Morphs-for-G8M-Vol.-1
There is a free one in this set: https://sharecg.com/v/94004/gallery/21/DAZ-Studio/InTheFlesh-Merchant-Morphs-for-G8M-Vol.-1
(If you haven't used ShareCG before, note that you need to register before you can download anything - it's free but you need to supply an email address. They don't seem to spam you though)
InTheFlesh no nose morph has some limitations. In most cases you won't get a smooth surface due to the nostril and textures of the original character.
