Victoria 6 "Diamond Skin" (SOLVED)
TheVestigeTheVestige Posts: 0
edited April 2014 in Daz Studio Discussion
Here's an odd one ...
If I take the Victoria 6 figure and scale it up (1000% in this example) and move the camera back a fair amount ... I get what I can only describe as diamond skin (see second image)
The problem goes away when the camera is moved back in close, or when I use the V6 Normal Maps.
It's not a huge problem as it only occurs with large scales (Haha, pun!) which I very rarely use, but I'm curious as to why it happens.
Thank you for any input you might have! =)
Post edited by TheVestige on
    If you are using Age of Armor's SSS shader you may need to adjust the Shade Scale (think that is name).
  • TheVestigeTheVestige Posts: 0
    I'm not using Age of Armor's, but I AM using a subsurface shader - so I looked for something along the lines of a shading scale slider and found one! Cranked it up and all is well.
    Mission Accomplished, thank you jestmart! =)
