Victoria 6
roberthutchinsonroberthutchinson Posts: 309
I purchased the Victoria 6 Pro Bundle a while back and I just purchased Domina Bundle. So, I have been away from DAZ work for a while, but now I am going back into it. I thought that in my Smart Content, that there was a Victoria 6 Character (actor) just like my V4, V5. But to my amazement there is not one showing up. Am I missing something, here?Is there a Victoria 6 actor figure in smart content? AND how do I get the Domina character to work? Where are the body, face, etc, morphs? They do not show up in smart content, unless I need to have Vic 6 loaded first, of which can not seem to find.
  • riftwitchriftwitch Posts: 1,439
    You should load Genesis 2 Female first. I don't have Domina, but she should be in smart content. There should be presets to load her there; the product page shows two, one to load the full character, the other to load just the head. If there are separate morphs, they should be found on the shaping tab.
    If V6 isn't showing up in smart content, make sure you have Genesis 2 Female in your scene first, and she is selected in the Scene tab. If she still isn't showing, you may need to re-import your metadata.
    They don't, because they aren't. In Genesis and Genesis2 the morphs don't need to be loaded into the figure, they're already in the figure when you load it. Look in the Parameters tab with the figure selected, and check the various sub-categories. You'll probably find what you're looking for under Actor>Female. (You could use the Shaping tab instead of the Parameters tab, whichever you're more comfortable with.)
    You should be seeing something in Smart Content, though. Can you see anything useful if you switch to the Content Library tab and look in Products or Categories?
  • JaderailJaderail Posts: 0
    edited April 2014
    Sorry SpottedKitty but they do have full Actor presets for full figure releases... look in Content Library Tab.>>>People>Genesis 2 Female>Charactors as shown here...
    358 x 746 - 117K
    Post edited by Jaderail on
    Smart Content Needs the Genesis 2 Female Base loaded and then you get....
    364 x 922 - 150K
    Ah, OK, I wasn't completely sure about that one.
