fail to render and save files
Hello, suddenly, I can't save my renders and I can't save my files anymore, what's happen ?
Do you get an error when you try to do it?
If using Windows, did you install a Windows update recently? Some people mentioned that a recent Windows update had changed the permissions on a lot of folders on their disk and set them to read only, so they had to set them as writable again.
What are your system specifications? What security software are you running? Can you save if yiou choose a different destination folder (try using File>Save Last Render)? Can you save from normally other applciations?
Yes I can save using "Save Last Render",, but I do not understand why I can't use the habitual way to,
