Free Bowl testing my DAZ Skills.
RorrKonn
This is my first DAZ mesh so let me know what I did right or wrong thanks.
Post edited by RorrKonn on
RorrKonn
@RorrKonn I'd say you did it all wrong... it leaves no impression whatsoever. Just kidding, I'm sure we all look forward to seeing the mesh, once you attach it.
I did,I did "attach a file" but apparently it was a bad idea.
Here's my next bad idea ? Since you wasn't impressed with my null ;)
https://sharecg.com/v/96091/browse/21/DAZ-Studio/RorrKonn_Bowl_423
You did do it all wrong.
jestmart tell me how to do something right
ALLIEKATBLUE thanks
Can you get the bowl in to DAZ ?
Does the Materials work ?
Folders missing.
I deleted the file for now.I'll try agian soon
You'll want to put the folders in the right folder directories - even for freebies, people don't want to have to move different folders around to different parts of their Library. Your included Directions said exactly the right places to put the folders, but people are lazy ((myself included lol)) and we would rather not be arsed with dropping multiple folders into different locations. I know... gift horse, mouth. :P
Once you get the files into the different directory folders it loads perfectly:
HERE is a Zip: https://sta.sh/01w8tm7z12yn https://1drv.ms/u/s!Atngb0fwji2dgj2Bo36BO4S7UXWb?e=dBJaz6 I've put the folders in the correct (hopefully) file hierarchy so that people can just drop the files in the "Content" folder into their "My Library" and not have to fuss with moving multiple folders around. :) I also made icons - just super quick icons, nothing special, but hopefully it will show the different textures clearly. I hope that's ok? If it bothers you, let me know - if so I'll delete the Zip. :)
Nicely done on your first Daz Studio freebie product! :)
Oh, don't do that! The bowl turned well - particularly for your first time making a DS freebie! The blue texture looks really nice, imo. The folders just needed to be placed in the right hierarchy, after that it's all good! Nicely done!
Setting up the friggin' folders correctly is a pain in the butt if you don't do it frequently. I've put out some freebies, too, and it always took me longer than the actual freebie itself. Seems I always forget at least one map and see the mistake that makes me redo everything only after the first setup is completely done...
Don't give up.
Divamakeup : Oh no I don't mind at all, zip away .Thanks so very much for your help. I need all the help I can get.
https://sta.sh/01w8tm7z12yn reads page not found ,sniff sniff. I signed in to https://www.deviantart.com and still can't get the zip.
I deleted my zip cause a bunch of extra files ended up in data and I'm going to attempt to make it smart.
I got Razor42 & DarkEdgeDesign tutorials and read DAZ & Renderosity venders rules is why there in the folder structure there in .
I never new freebies went to My Library..Thanks a lot for letting me know :)
JuNe : Surrender is never a option ,Thou I might end up in gothams asylum ;)
I don't know what is up with the sta.sh link not working -weird. Try this link instead: https://1drv.ms/u/s!Atngb0fwji2dgj2Bo36BO4S7UXWb?e=dBJaz6
Let me know if that works or not. If that one doesn't work I'll try uploading to Google Docs. :)
YA !, It worked :) Thanks so much .
it's late n got to go but real fast.
can you post a path like
I missed my files up so I know it not right but its something like this ?
C:\Users\RorrKonn\Documents\DAZ 3D\My Library\content and that's where the content folder goes ?
Im going to fix D/S tomorrow.
Thanks again
Yeah, just where ever you have your content library installed. Mine is on G drive, but I THINK the default location is: C:/Users/Public/Documents/My DAZ 3D Library (I'm not 100% sure though, because it's been years since I used the default location).
Open up the "Content" folder and just drop those files into "My Library" or "My DAZ 3D Library" (whichever one you have) and that should work. :)
What bathroom & products did you use? Looks so real!
Yeah.. this is pretty neat. If the OP can make a soap dish and Toothbrush holder to go with it, it would be a bang on first set!
This like is working https://1drv.ms/u/s!Atngb0fwji2dgj2Bo36BO4S7UXWb?e=dBJaz6
And it is working perfectly.
Wrong again. Do not include 'vanity' folders "RorrKonn Bowl Freebie". Do not include "Content" or "My Library" folders. The "data" folder and other files and folders (that belong to the product/project) at the same level as the "data" should be included. This makes it a simple extract and play zip.
lol I think the "wrong" is on you this time. :P All Daz3D store content come in "Content" folders. The "RorrKonn Bowl Freebie" folder isn't what is called a "Vanity" folder, that's just a container folder, which is perfectly fine for freebies. The "vanity" folder is the one in Props called "RorrKonn_Props" - and a lot of PAs also use vanity folders. While I personally don't like vanity folders, a lot of PAs use them, and that's valid too. It's not "wrong".
It's an HDRI: https://hdrihaven.com/hdri/?h=bathroom
I made the RorrKonn_Props and RorrKonn_Textures folders to keep my stuff organized .I would guess that's why a lot of Pa's make them that way .Whats PA stand for ?
I never could get DAZ Studio reset to default but I have C:\Users\RorrKonn\Documents\DAZ 3D\Studio\My Daz Connect Library\
C:\Users\RorrKonn\Documents\DAZ 3D\Studio\My Daz Connect Library\RorrKonn_Bowl_423\data
C:\Users\RorrKonn\Documents\DAZ 3D\Studio\My Daz Connect Library\RorrKonn_Bowl_423\Props
C:\Users\RorrKonn\Documents\DAZ 3D\Studio\My Daz Connect Library\RorrKonn_Bowl_423\Runtime\textures
So I put the bowl in there and it works.
I spent most the day trying to unsuccessfully reset DAZ.So I didn't get to Smart content yet
But I do get I just need data,props,runtime in any folder anywhere on the PC as long as DAZ sees the folder ,right ?
I'm going to go check my self in to gotham asylum now .
PAs are Published Artists - the term used for Daz3D vendors.
And yeah, you can name your Daz Library anything you want, and (as far as I know) put it anywhere you want - as long as you point Daz Studio at it so that it knows where the content is.
I would recommend using DIM for the installs but that's just a personal preference. Many people like to manually install and I think some use the new Daz Central.
Don't stress it too much, 3D art is meant to be fun. :D Take it easy and just work on it when you feel up to it, don't let yourself get to stressed.
I am not wrong. DAZ3D zips are designed for DIM which strips out the "Content" folder. Whether you call it a vanity folder or Clyde it doesn't belong.
Ah, OK, thanks. I thought, wow, what a realistic 3D model, they even put fraying on the edges of the mirror and old dirty caulking lol...
No one fused about the bowl it's self or poly count or UV map.So I guess every things good.
BTW we do have a freebie forum for people who want to give freebies away
https://www.daz3d.com/forums/categories/freebies
I read the becoming a vender page .I get that DAZ makes the content smart.
I have a collection of containers.
I'm I to make sets ? ready to renders ? I'm not sure what I am to do about this stuff ?
