Genesis 2 Female Genitalia Texture
Hi guys
I dont know if there is another thread like this but here goes...
The problem I'm having is this:
I have Genesis 2 Female Genitalia that came with the Genesis 2 Female Pro Bundle. When I copy the "Hips" texture for Genesis 2 Female and paste it on the "Hips" for the Genitalia, the texture on the Genitalia appears substantial lighter than the rest of the figure.
This is on "The Girl 6"
Thanks in advance!
Image removed See the forum ToS bullet point #1 Terms of Service
Post edited by Chohole on
Try clicking both the Girl 6 and Genitalia surfaces and scene items together (control key) and then going to the material file and loading the texture for Girl 6, instead of doing it separate. I had a similar problem quite awhile ago, and forgot how I corrected it, but it is doable.
Sounds like it may well be a shader issue. Copy/Paste between material zones doe not, sadly, copy across the source shader. So if the main figure has, say, HSS, US, or AoA SSS shader in use then you'll need to, before doing the copy, make sure the target amt zone is set up with the same shader.
