Old content with RSR files
TSasha Smith
I knew of a program that would convert RSR files into PNG files. Poser 2012 does not read RSR files and it is sometimes hard to figure out what an item is without the thumbnails.
What is a good free program that creates PNG files from RSR files? I thought I found one but I could not figure out how to download it.
An RSR thumbnail is a .pict file with the extension changed - you could rename them to .pict and find a graphic app that will convert them to .png, though I think there are (or at least were0 tools that would do that directly from .rsr.
a google search gives several different tools for doing this https://www.google.co.uk/#q=convert+rsr+to+png
I use this one, works fine, though there sometimes are files that it's unable to convert - whether the problem is with the program or the files I don't know.
http://neocron.webspaceforme.net/library/installer/RSR Converter_1_0_0_1.zip
OK, link doesn't work with this forum, you must copy-paste it for it to work.
Hm, first link doesn't work it seems, this one (a newer version) should:
http://neocron.webspaceforme.net/library/installer/RSR Converter_1_0_0_2.zip
I use this:
http://www.senosoft.com/softp3do.php
Very simple to use. Open it up, browse to the folder where the .rsr files are, go to tools->convertrsrpng and it converts all the rsr's in that folder to png's.
That's what I've been using for a long time as well, though I've only used it recently when I installed some older products I hadn't reinstalled when I got this laptop 2 yrs. ago. Some vendors were including both RSR and PNG files, but a lot of older, circa Gen3, only have RSR files. This little app really comes in handy.
Personally you'll find no better option.
The same program can be used as a library manager for loading poser content into DS or Poser.
