Old content with RSR files
TSasha SmithTSasha Smith Posts: 27,419
I knew of a program that would convert RSR files into PNG files. Poser 2012 does not read RSR files and it is sometimes hard to figure out what an item is without the thumbnails.
What is a good free program that creates PNG files from RSR files? I thought I found one but I could not figure out how to download it.
  • Richard HaseltineRichard Haseltine Posts: 109,329
    An RSR thumbnail is a .pict file with the extension changed - you could rename them to .pict and find a graphic app that will convert them to .png, though I think there are (or at least were0 tools that would do that directly from .rsr.
    a google search gives several different tools for doing this https://www.google.co.uk/#q=convert+rsr+to+png
  • TaozTaoz Posts: 10,295
    edited April 2014
    I use this one, works fine, though there sometimes are files that it's unable to convert - whether the problem is with the program or the files I don't know.
    http://neocron.webspaceforme.net/library/installer/RSR Converter_1_0_0_1.zip
    OK, link doesn't work with this forum, you must copy-paste it for it to work.
    Post edited by Taoz on
    Hm, first link doesn't work it seems, this one (a newer version) should:
    http://neocron.webspaceforme.net/library/installer/RSR Converter_1_0_0_2.zip
    I use this:
    http://www.senosoft.com/softp3do.php
    Very simple to use. Open it up, browse to the folder where the .rsr files are, go to tools->convertrsrpng and it converts all the rsr's in that folder to png's.
  • Miss BMiss B Posts: 3,071
    edited April 2014
    jakiblue said:
    I use this:
    That's what I've been using for a long time as well, though I've only used it recently when I installed some older products I hadn't reinstalled when I got this laptop 2 yrs. ago. Some vendors were including both RSR and PNG files, but a lot of older, circa Gen3, only have RSR files. This little app really comes in handy.
    Post edited by Miss B on
  • MattymanxMattymanx Posts: 7,000
    Miss B said:
    jakiblue said:
    I use this:
    Personally you'll find no better option.
    The same program can be used as a library manager for loading poser content into DS or Poser.
