eyelashes shadow? in render problem-help!
IsodoriaIsodoria Posts: 0
edited April 2014 in New Users
hi all, can't get the eyelashes right in the render. Help please! need eyelashes to be in the right spot.
Eyelashes look like they are coming out of the middle of the eye.
Thanks,
Isodoria
Post edited by Isodoria on
  • frank0314frank0314 Posts: 14,767
    What is the issue your having. Your post is a bit vague.
  • SixDsSixDs Posts: 2,384
    Isadora, it looks as though you have a light positioned immediately above and in front of the forehead that may be causing the problem. I'm not sure whether this is causing the eyelashes to cast shadows onto the eyeballs or if they are being reflected. Try adjusting your lights slightly, or pssibly the camera position.
