Particle in my eye
richard.chaos_91798ec102
I could of sworn there was a way to make the DIAMONDS particles in a particle emitter to POINT towards a certain camera!
Now i can figure it out?
PLEASE ADVISE
use an object in the particle emiter and use a point at modifier on it
I did it with a bulb with a crosscreen effect, and parented the emiter to a dancing figure's hand, very purtty
http://www.youtube.com/watch?v=Qqn2M_sWmKk
Hi Richard...this is how I do it...sure there are other ways.
Load a new scence
Drop in a particle emitter
on the modifier tab (emitter) choose point at camera (1) and check z+
then in the model room I go to the advanced tab and change gravity to -1.00
that should get you started.
Jim (using the 8.5 beta)
Is there any way to have the DIAMONDS to come out of the emitter randomly rotated?
I have yet to use emitters successfully...but the coder geek in me sees the word "randomly" and immediately offers the uneducated answer of "No." To my knowledge, we don't have any programmatic ways of controlling Carrara. That would be a pretty sweet feature to have though!
Try the ORIENTATION controls towards the bottom of the Particles Creation area.
Maybe this is what you were remembering?
I tried a few things and discovered I could use an object...a single polygon...shaped like a diamond... and then rotate it along the timeline...not sure if it is what you are looking for but I did learn some things ... thanks (and Holly, too)
http://youtu.be/ncxnx5umdR0
try splat with a transmap
