Environment used in Pool Table and Darts
in The Commons
https://www.daz3d.com/z-pool-table-and-darts-for-genesis-8
From what I can tell, the interior environment with brick walls is not included in this product.
It doesn't mention the environment used either.
Does anyone know what product is used for the room with the bricks and neon signs?
I looked through all the environments in the DAZ Shop but I do not see something that matches the room used in this product.
The same environment was used by Zeddicuss in a much older pose set over at Rendo called "Z Luscious". I assumed it would be a bar either by Zeddicuss themselves, or by what was once i13, but I can not find it. It might be a kit bash.
Thanks! I will keep looking and I will check out Z Luscious.
i13 has some incredible sets. They are still in the DAZ Shop, so I was not sure what you meant by "what was once i13".
They could have just added several planes for the floor and walls and added a texture
It looks similar to this product, but not quite, so I think you could be right about that.
https://www.daz3d.com/the-brass-pole-nightclub
Its actually this set here :) https://www.renderosity.com/mod/bcs/svs-neon-nights-quick-scene-ds-iray/117002/
Wow! Thank you so much! That's it!
i13 was a group that has now split, two parts of the group are now called biglovepose and Ironman now.
