Lighting problem
How do I get my lights to work correctly, without creating the blackout shadows. This is with the headlamp and the lantern.
  • Richard HaseltineRichard Haseltine Posts: 108,488
    I'm probably bening dense, but what do you mean by blackout shadows? I wouldn't suggest using the headlamp in any event.
    Hide the dome in the render settings.
  • dennisgray41dennisgray41 Posts: 860
    The shadows at the edge are blacking out the globe making it look lumpy. I looked back at my settings and most of the unwanted reflections are coming from the Dome. If I turn off the dome, I get no light. With no dome and a distant light, I get almost no light.
  • HylasHylas Posts: 5,231
    Pick a different HDRI.
    Also, did you make a floor by putting a black square on the ground?
    I would rather have no HDRI
    The floor and background are a prop that came with the snowglobe.
  • SevrinSevrin Posts: 6,313
    Then go sun/sky or pull the HDRI.  This isn't so much a lighting issue as a reflection issue.
