Imported OBJ moves location after using Transfer Utility G8F
• I created a obj in Blender.
• I imported the obj into DAZ and it's in the proper location.
• I ran Transfer Utility and fit to G8F
My issue is now the obj moved out of loction?
  • felisfelis Posts: 6,025
    Is it created to match the default G8F?
    Check to 'reverse deformations' too. If the figure is not the default figure [i.e. with a figure morph dialed in], then select 'current' on the donor.
