Tight fitting lingerie?
JPJP Posts: 97
Hi,
I've been playing around with some lingerie for G8 Females. The stockings match the shape of the character's legs but hover slightly above the surface. The result is you see some drop shadow effect. This is more pronounced with sharp ligting which creates more pronounced shadows. This is not 100% realistic or convincing. Is there a way to make the stockings fit more snugly? I've tried reducing the scale of the clothing article to 98 or 99% however this increases the hovering in some other parts of the character.
I guess the other option would be to opt for stockings that are mapped onto the surface of the skin. But then it becomes a pain to remove in case you decided to opt for something else.
The RealFit products have a nice, realistic tight fit. But they don't have a lingerie product.
Any suggestions will be appreciated. Thanks!
  • JPJP Posts: 97
    Here is an excellent example of what I am going after. How was this done? With geoshells and mesh smoothers?
    https://www.deviantart.com/forged3dx/art/Stockings-for-Geoshell-G3F-G8F-661034681
  • JPJP Posts: 97
    I should have read the site links. This is how it was done. I am going to try this!
    28 Jun 2017 - UPDATE: Thanks to thedude561 for pointing it out, these also work on G8F :)
    3 Feb 2017 - UPDATE: I've added a map for fishnets. Also, I've added a displacement map for the G3F figure torso that will make it appear as the skin is bulging out above the stockings to make it more realistic.
    Hi all, my friend MTaylorART wanted some stockings so I thought I'd make a quick few and share them.
    In the zip file is a few opacity maps for stockings designed for a geoshell for the G3F character. Also in the .zip file is a template file to make your own with a software like Photoshop or GIMP.
    Instructions are provided in the .zip file.
    Enjoy!
