Problem with GenX2
I am trying to transfer some V4 morphs to Genesis 2 Female. I am getting this error: "Error loading target morph: GXC_Victoria4". Can someone help me, please?
My V3 to G2F transfers are working properly
Here is another problem. I transferred a V3 Character to G2F, then tried to fit some high-heeled shoes (Out Of Touch Sexy Pumps). I set both the GX2 "Victoria 3" Morph and my Morph to 1, set the foot pose, then conformed the shoes. What am I doing wrong? It looks like the foot bend is getting severely distorted.
The above problems are pretty serious. If no one has a reasonable solution, then I better get a refund.
It's important to note that transferring morphs between figures isn't an exact science. Since the meshes are completely different, it won't be a perfect match every time though it does a fantastic job of approximating the differences. With regards to the footwear, are they designed for use with Genesis 2? No amount of tweaking is going to make V3 clothing work on Genesis without a proper clone figure, and shoes are notorious for not behaving under even the best of circumstances with autofit.
As for morphs, be advised that some morphs won't transfer for a variety of reasons. The main one being that many of them are fixer morphs which won't have much, if any, bearing on the actual appearance. Unless you're getting noticeably bad results from a particular morph, I wouldn't panic about seeing a few of those messages pop up.
I think it's setting the V3 foot pose that goes wrong. V3 and Genesis2 have different bones, so you don't get exact results using Generation 3 poses on Genesis or Genesis2.
Thanks HeraldOf Fire, Kerya.
Neither V3 not G2f shoes will conform properly. In my example, I am using OOT's G2F Sexy Pumps. The foot pose is very simple foot bend=55, toe bend = -55. It should not distort as much as shown. I would suspect that the problem would be worse with a V4 morph transfer.
