[Solved] UltraScatter Advanced Instancing Help
3Diva
I have UltraScatter Advanced Instancing for Daz Studio and the "Reference Guide" PDF Script won't work, so I can't access any directions or tips. There doesn't seem to be instructions via the Read Me either. The product script itself works fine though. I just need to know what settings to use to make a believable flock of birds. I've tried experimenting with the product and trying different settings but I'm still having trouble getting decent results. Things seem to just stack on top of each other and inside of each other.
Could I get some tips/advice on how to get a flock of birds? Or a link to the PDF? Or at least a nudge in the right direction on which setting(s) will keep the instances from stacking inside of each other?
The pdf should be in scripts/ultrascatter/resources in the library you installed the product to.
@Divamakeup You can get to the PDF by using Windows Explorer and going to YourDAzLibrary/scripts/ultrascater/resources and opening it there. the link in daz studio didn't work for me either
@namffuak @Kharma Thank you. Going to the "Resources" Folder and dragging that Reference Guide PDF into Chrome opened it up. Thank you! :D I'm not sure why the script won't work.
I appreciate the help!
