Daz Metric install error
Install Manager cannot find a required path. The installer for "Measure Metrics for DAZ Studio 4.5+ (Win 64-bit) Public Build" requires that the installed path for "DAZ Studio 4.x Public Build (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
What?? I don't know exactly whats going on here? I use install manager for installs
"Public Build" is the beta. The release version won't say Public Build.
so what does that means? what do i do, at this point?
You install the Measure Metrics system that does not end with Public Build. The Public Build is only for the Beta of DAZ Studio which you do not need. You do not have the Beta of DAZ Studio installed or the file(s) would install. If you Right click the Files in DIM you can set them to hidden and they will not list in your DIM until you un-hide them again.
oh okay... so I it tries to install both packages, automaitically... the proper one is already installed.... got it..
