Question about Carnival Presets
DkgooseDkgoose Posts: 1,451
I'm just wondering if this is loading everything right, there seems to be a whole lot of emptiness. I have all the required products needed. Here is a picture of everything loaded.
  • JGreenleesJGreenlees Posts: 2,249
    The carnival booths (joints) usually rundown the center of the lot. The rides and attractions ring the outside of the lot. From the image it looks like things aren't set properly. The joints on the ground plane that's out of alignment should be forward and then the rides should be on he ground plane. i will take a look at the set again to see if it's not loading correctly
  • DkgooseDkgoose Posts: 1,451
    I just realized I was loading the carnival presets from the poser runtime not the one in the Daz library, I wonder if that's why it's not loading right. Although I only get error messages with the one in my Daz Studio library :/
