Material Presets for Groups
Can I create a global material preset for a group of items? Say I have grouped dishes in multiple stacks and I need a one-click solution to change the color or shader setting for all. The first in each stack is a unique object, the rest in each stack are instances.
I've tried selecting the objects then doing a material setting to save, but when I reload the set, select the same objects, and apply the new material setting it doesn't work.
  • LeanaLeana Posts: 12,860
    Instances all have the same materials so I would assume that a preset applied to the main item should apply to all.
  • NorthOf45NorthOf45 Posts: 5,725
    If they are all instances of the same prop, they will follow the original. If there are several different props (with or without instances), save as a hierarchical material preset. A good practice would be to create a new group node and add the props and/or figures then save the hierarchical material preset with just the group node selected. To apply it later, select the group node (not the items in the group).
  • jardinejardine Posts: 1,217
    edited July 2020
    ditto what NorthOf45 suggests.
    i always group related scene objects.  but i didn't discover hierarchal material presets until this month.  it's a great trick, and a huge timesaver.  :)
    Post edited by jardine on
