ISO: Basketball Hoop
MJ007
... with the net having movement morphs.
Is there one anywhere?
-MJ
MJ007
-MJ
what program are you using?
DS2.3
damn. I know in Poser you could use the morph brush to create the morphs you want, not sure if studio has anything like that
hey were you the one looking for an inner city basketball court a while back?
Yup... that was me.
-MJ
i found this one a while back
http://www.renderosity.com/mod/bcs/stz-streetball-court/100300
Yeah, i was aware of this set. The fact its half-court only kinda killed it for my purposes.
-MJ
ok, well if i find one i will give you a heads up
Since all i really need is a net for the City Streets court, at this point, I think Im going to postwork a net to handle the effects i need. I suck when it comes to postwork, and avoid it at all cost, but for a net, I think thats a small enough task to handle. But your assistance is always appeciated.
-MJ
if you have hexagon or some other modeling program you should be able to do the morphs you need in there
Can't you set up a deformer (or a couple of them) to distort the net?
Im even worse at modelling/morphing than I am texturing. However, the rims in City Streets do not have a net at all. But that is another option I didnt consider... once i find a rim with a net I can parent to the set.
-MJ
