Padlocked Morphs seem to be stuck...
Recently I locked (via the padlock icon) several morph dials on my V4 character (I'm using DS 4.6, latest version). Yesterday I noticed all of the padlocks were "open", so I thought that everything had gotten unlocked for some reason. But when I tried to change a dial it wouldn't let me. It's like the morphs are still locked and there's no way to unlock them. I tried right-clicking and unlocking selected properties but nothing happened. I also tried clicking on the padlocks but nothing happens either. The padlocks close and open when clicked, but the dials are permanently locked in place.
Any ideas on what could be causing this?
Had you saved the scene and reopened it in DS between the time you set the padlocks and the time you discovered this?
Only thing I can think of is that something fails when opening the file again (I've bugreported another issue when setting made to the object is set to the stored content duf values, not the changed ones in the saved file.
Btw, what version of DS 4.6 do you use?
I'm using 4.6.1.17 (64-bit).
And yes, I basically saved a scene after locking many morphs. Then one or two days later when I opened the scene again I ran into this problem...
I was able to find an older scene with the same character with morphs unlocked, and am working off of that. I'l be more careful in the future with locking just in case :/
