Problem with Character
edited April 2014 in New Users
Everything is perfect on the scene,
After exporting the character the clothes don't stick to the character,but they appear.
I don't know what to do,can you help me with that?
and i need the character as fbx so don't offer me to export that as other format please.
The first image is on the scene,before the export.
The second image is export settings.
The third image is after Importing the exported file.
Post edited by quadpowerful_370c6e3ee1 on
  • JaderailJaderail Posts: 0
    edited April 2014
    Please post your images in-line in the Forum post.
    Here is how... Write your post using the full Post not a Quick post... Under it will be Choose File, click on it and browse to the file on your PC and Accept.
    To Add a second Image you then Click Preview Post, and then Choose File again.. you can add up to 5 images at the bottom of your post this way as long as the File Size Total in not gone over.
    The Forums will automatically re-size the image to the size to fit the Forum and the Viewer can click that image to view it full size. That will allow you to show better Images with more information. That will allow us to better help you as well.
    EDIT: As for the FBX export here is some information. FBX is one of the file types that as yet has no One standard at this time. The FBX code in one program may or my not match the FBX code in another program. It is like the TIFF image format. No set standard at this time.
    I do hope other users here can help you as many do use the option. I'm not a user the needs that function but do know that FBX is and or can be different from software to software. That can cause issues.
    Post edited by Jaderail on
    Please See my EDIT and Thank You.
  • edited April 2014
    I uploaded the images,
    and I used just daz3d,
    I exported the character from daz3d,then i imported it to daz3d.
    so compatibility between softwares can't be the problem.
  • fixmypcmikefixmypcmike Posts: 19,709
    Do you have the same issue in the program you are using FBX for?
  • edited December 1969
    Yes.
    I do not use the FBX option but with Merge Clothing to Figure on I do not think you should have Convert to Static selected as well.
    435 x 638 - 47K
    Thank you so much!
    It's working!!!!
    Your more than welcome. Have fun.
