Adding to Cart…
what DAZ studio calls opacity maps
if you look in Carrara they are called alpha
The first thing I noticed is when loading the complete environment, eight cameras are loaded. Each camera has it's own fog prop, so eight fog props are loaded as well! I did two 500 sample test renders, one with all eight fog props visible, and one with only the fog prop for the camera I was using. With only the one fog prop visible, the image rendered noticably faster. I didn't add any figures or additional props to the scene, though.
So far, I think this is an awesome environment with a lot of potential. I'm glad I bought it. However, it would have been nice to have some instructions regarding those fog props, especially for new users.
I have a 980Ti 6gb card. I used one of the preset cameras, hid all the rest of the cameras and fog props and rendered. I tend not to use others render settings but use my own instead, so that's what I did. This is 2000 px wide, had no trouble fitting on my video card with no adjustment of image map sizes. I set the denoiser to come on at 100 px and it's a total of 345 pixels (it is a test, after all). It took almost exactly 5 minutes. I think my gfx card can handle it ;).
This might just be my favorite environment outside of a Stonemason set. The attention to detail is phenomenal. I love dirt, cracks, damage...I love WEAR. It's always bugged me that most sets I purchase are so clean that it immediately gives them away as 3D. Even new houses have small imperfections. Great set! :)
Laurie
I did another export to Carrara this time with all the alpha/opacity maps by using a free iray to 3Delight script by Esemwy on all the surfaces, the paid one in the store might even work better for you @tsarist as automatic, I had to select everything and every surface
its here https://www.daz3d.com/forums/discussion/139326/irayto3delight-conversion-script/p1
the lights will be too bright for Carrara, you are better off doing your own
+1 That's one of the things I love about this set, as well as Strangefate's work, and a couple of other PAs - they bring the imperfections and wear and tear that real places and real things have. Like you said, even the newest of items will have a little bit of imperfection. And most of the real world isn't even close to new. Environments that are too clean, too perfect, it's all a dead give away that it's 3D. I hope that we see more environments like this! I love it!
You may have just solved an issue I was having with this set. It was taking aaaaages to render, on what I would say is a decent spec machine! Even after 6 or 7 minutes it was really grainy and not really usable. And that was without any figures! I shall have another look and try removing the fog props, and see if that helps.
For reference, my rig is a Ryzen 9, Win 10 64bit, 64GB RAM, running 2x RTX 2080 TI's in non-SLI mode.
I finally got to play around with this awesome environment today, and used the new character Shizuka who I think is an absolutely incredible character!
Oh my...I completely forgot about Strangefate. OMG yes....excellent detail. I have both the bedroom and the tavern :). I love vendors that go above and beyond on the texture work :) I hope we see more of things like these too! I will always buy them on the spot.
Laurie
This is a gorgeous render.
@spuffy thank you so very much
great renders everyone :-)
Boyd wants to add his t-shirt to the load in progress.
a few loads being added there but I see he has some belly button lint too
