Transgender morphs
I was wondering, if there is anything at all for G2F (Victoria 6) in particular, so that I can create masculine features. After looking through other threads, it seems that it would be possible with either V5 or M5, is that true?
I've been stuck with Victoria 4 for a few years, but hoping to move on with subsequent base models and create unique lgbt characters.
Thanks.
  • LeanaLeana Posts: 12,822
    V5 and M5 are based on Genesis 1, which is a single figure which can become male or female.
    Genesis 2 male and female are separate figures, so you can't do that directly.
    One option to get a basic male shape is to use the G2M clone morph, which is used for autofit. You will find it in Parameters tab when you have "Show Hidden Properties" turned on, it's under Hidden:Clones.
    As Genesis 2 male and female are based on the same mesh, another option is to export G2M as obj and load that as a G2F morph.
    It's also possible to copy and modify G2M morphs files so that they work on G2F, but that requires quite a bit of fiddling.
  • HavosHavos Posts: 5,600
    Another option is to use Generation X to move as many male morphs and shapes as you want from G2M to G2F.
    Another unconventional option is to simply copy the relevant dsf morph files in the data area from the male to the female area, and then edit them to rename any instances of Genesis2Male to Genesis2Female, but this method is not for a novice. This is possible because G2F and G2M are actually based off the same mesh. It doesn't work for Genesis 3 and 8.
  • davesodaveso Posts: 7,846
    i'm a bit confused as to what this product does. I bought it, thinking possibly i could change a g8m into basically a g8f, etc etc, but i found that not to be the case. at least in my attempts... and vice versa, the breat morphs didn;t seem to do much if anything.
  • Steel RatSteel Rat Posts: 417
    That's because "gender" is behavior, and "sex" is biology. "Transgender" has no bearing on physical attributes. Should be, as it used to be a decade or so ago, "Transsexual".
  • kyoto kidkyoto kid Posts: 41,965
    ...Genesis "Classic" (or G1) also has an Acrogenous Morph which can be imported through GenX/GenX2. I've been using it with G3 for custom characte creation.
    I like the free ones on deviantart by agentunawares https://www.deviantart.com/agentunawares/art/Transgender-Genesis-8-723851486
