Nevermind! (Download issue, wasn't server related)
tj_1ca9500b
I was doing the manual download thing as I often do after placing a few order, and was chugging along nicely. Then, BAM! my 'currently downloading' downloads fail inexplicably. I try to resume said downloads, they go for a second or two, then fail again. I try to re-download said files, again BAM! Failed downloads within a second or two of beginning the download.
So I waited a few minutes, then tried again, downloads are still failing. Not a connection issue (I disconnected then reconnected to the internet just to make sure), as I'm typing this post of course.
Just wondering if something might be amiss on the server end...
Edit: Turns out I grabbed the wrong USB drive. I thought I had grabbed the one with plenty of space left, but I grabbed the almost full one instead (they look identical). Once it filled up, the downloads automatically terminated immediately with no indication as to why... nothing to see here, move along!
Post edited by tj_1ca9500b on
Once you get a failed download you shouls clear your browser cache before trying again as the faulty download will tend to stay an the cache and cause subsequent download attempts to fail in the same place.
Have you checked that you have not ran out of space on your download drive?
