FaceGen Exporting formats
Hi everybody, I created a face in FaceGen and I would like to export the model as .obj
It looks like I can only export it to Daz Studio... I attached a screenshot of the export panel
  • 3Diva3Diva Posts: 12,014
    edited June 2020
    If you just want to export it as an OBJ, just make sure the FaceGen morph is dialled in then go to File >> Export and you can export the figure as an OBJ.
    Edit - If you're going to use it as a base for a Morph, then you'll want to make sure the figure's Mesh Resolution is set to "Base" first before exporting it as an OBJ. (Parameter's Tab >> Mesh Resolution >> Resolution Level >> Base)
    Post edited by 3Diva on
  • Thank you, I'm new to the software... how do I dial the morph?
  • nonesuch00nonesuch00 Posts: 18,812
    To export as an OBJ directly from FaceGen (and get the much higher accuracy) you need a different FaceGen product purchasable directly from the Singular Inversions web site. Hold onto your hat though I think it's very expensive! ($299 it says)
    https://facegen.com/modeller.htm
