LRay addon for West Park making floors invisble if i use water puddle materials
Hi
New to DAZ3d and enjoying it so I bought the lray addon for West Park so i could create scenes for my images and its all going great but! if i say assign an lray material with a puddle to a corridor floor I can see the puddle but the floor is now transparent.
The floor in question is WP_cor_cflr i thought i would ask rather than spend all day messing the settings up and getting really confused.
Thanks in advance
In the surfaces tab, does the floor have more than one surface? If there isn't puddle already on there (i.e. a separate "puddle" surface) then it would just turn the floor to the water shader - if there is two surfaces (i.e. when you expand WP_cor_cflr in the surfaces tab it shows "Floor" and "puddles" for example) make sure you are only applying the water to the puddle surface.
Thanks for the reply I could not figure it out and I was on a deadline so just used the orignal materials.
I am sure it has something to do with my rearranging the the original westpark and then just adding in the materials from the addon manually.
