Rough edged reflections
zug22zug22 Posts: 73
When I make a mirror it creates the reflection just fine in renders except that the reflection does not seem to have any anti-alising on the edges. I just bought the Useful Mirros product hoping the texture in it would fix this but it sems to have made no difference.
How do I set up a mirror material or shader to give smooth edged reflections?
See attached image for an example.
    Version of DS, render settings and lights used...
  • zug22zug22 Posts: 73
    edited March 2014
    DAZ 4.6.2.117
    Lights: 14 spots in a ring around the mirror and a single ceiling spot. It makes no difference with or without the mirror lights.
    6 distant lights set up for fill only (no reflections)
    Render settings:
    bucket size 64, ray trace depth 2, pixel samples 4, shadow samples 16
    Gamma 1.0.
    Hey, I don't think I have ever changed them. (?)
    Post edited by zug22 on
    zug22 said:
    DAZ 4.6.2.117
    Render settings:
    Gamma 1.0.
    Try upping the Pixel Samples...6 or 8 (3DL seems to prefer numbers divisible by 2 for this one...) and a ray trace depth of 3 or 4. Shadow samples...24. And the big one...shading rate, drop it down to something less than 1 (0.5 or lower).
    Warning...doing those changes will INCREASE render times, possibly significantly.
  • JaderailJaderail Posts: 0
    mjc1016 said:
    zug22 said:
    DAZ 4.6.2.117
    Render settings:
    Gamma 1.0.
    Warning...doing those changes will INCREASE render times, possibly significantly.LOL! Possibly?
    edited March 2014
    Okay, I tried that, the results are better but still not quite right: although the person has improved, the room now has wavy things in it - the doorway is now hairy ! Thanks for the suggestion anyway.
    Oh yes. render time did increase, but I'm not concerned.
    799 x 603 - 266K
  • prixatprixat Posts: 1,617
    edited March 2014
    The shading rate has a huge affect on reflections.
    The only difference between these images is a Shading rate of 0.2 and 1.0
    400 x 600 - 48K
    400 x 600 - 46K
    Post edited by prixat on
