Load a UV
konkon Posts: 389
Does anyone know how to load a UV?
  • AJ2112AJ2112 Posts: 1,417
    Surface editor > UV sets
  • konkon Posts: 389
    What folder would the uv sets be in?
  • JaderailJaderail Posts: 0
    You do not load a UV with the system browser, it is done inside DAZ Studio using the Surfaces Tab as just posted.
  • konkon Posts: 389
    its not letting me change the uv so I went to load uv sets. So in what folder would uv sets be found? trust me I know you can just click and change uv's but I need to load them for this
  • fixmypcmikefixmypcmike Posts: 19,702
    What figure is it, and what UV set are you trying to load?
  • konkon Posts: 389
    iam using posions genitals but its set for m4 uv only if I can load m5 uv the m5 textures should fit.
    You can only load a UV if it uses the same mesh.
  • konkon Posts: 389
    hmm well the m5 genitals don't shape good at all even scale it looks flat
    M5 Gens should reshape to the figure they're parented to.
    As for UVs, both items need to be the exact same mesh but with different UVs. You can then load a new UV set using Edit -> Object -> Geometry -> Load UV set. This will read in an OBJ file and, as long as the meshes are identical, apply the OBJ's UV's as an optional UV set available in your surfaces drop-down box.
    If you want to create your own UV set, make sure you export the item without any subdivisions. You can disable them in the parameters pane.
  • konkon Posts: 389
    Ok but even if I knew how to make a uv or what it looks like in what folder would they be?
    In whatever folder the .obj file is saved. For example, if I wanted to add the M4 UV set to V4, it would be in Runtime:Geometries:DAZPeople
    It will be wherever you saved the OBJ. An OBJ is just a standard model file. You edit the UVs, export it as an OBJ and then import it by using the 'Load UV set' option I described.
    Once you import it, it will appear in the drop down list automatically as an option for that figure. It saves the UV sets in the respective figures folders as a unique file.
