LRay addon for West Park making floors invisble if i use water puddle materials
PitmaticPitmatic Posts: 1,007
Hi
New to DAZ3d and enjoying it so I bought the lray addon for West Park so i could create scenes for my images and its all going great but! if i say assign an lray material with a puddle to a corridor floor I can see the puddle but the floor is now transparent.
The floor in question is WP_cor_cflr i thought i would ask rather than spend all day messing the settings up and getting really confused.
Thanks in advance
  • KA1KA1 Posts: 1,012
    In the surfaces tab, does the floor have more than one surface? If there isn't puddle already on there (i.e. a separate "puddle" surface) then it would just turn the floor to the water shader - if there is two surfaces (i.e. when you expand WP_cor_cflr in the surfaces tab it shows "Floor" and "puddles" for example) make sure you are only applying the water to the puddle surface.
  • PitmaticPitmatic Posts: 1,007
    Thanks for the reply I could not figure it out and I was on a deadline so just used the orignal materials.
    I am sure it has something to do with my rearranging the the original westpark and then just adding in the materials from the addon manually.
