G8 Eyelashes
in The Commons
Is there any way to fix eyelashes being in the wrong place with certain morphs? I made a custom morph and the eyelashes are not on the eyes anymore it was just a simple facial morph not to extreme
On the Parameters Pane, right-click on your new morph to go into Edit Mode. Then click from the cog wheel, select the Parameter Settings, check 'auto-follow' ... then refit the eyelashes and they should [hopefully] go back into place.
Thank you, I'll give it a try
