Hiro Toon Neck
MJ007MJ007 Posts: 1,716
edited March 2014 in The Commons
In testing the Tintation for HiroToon product, I encountered the following errors with the textures not applying to the neck and giving me an odd result. Im pretty sure I recall the mentioning of this error on the old forums, but i dont recall the reason it occurs or the fix for it.
Anyone have any ideas?
-MJ
Post edited by MJ007 on
  • TSasha SmithTSasha Smith Posts: 27,432
    Looks like a texture map not made for the right uv map scenario.
  • frank0314frank0314 Posts: 14,784
    Yes do you have the proper UV maps applied to the texture. Just use the UV switch to select what the character was made for. Assuming your applying it to Genesis that is.
  • MJ007MJ007 Posts: 1,716
    edited March 2014
    Im not sure what you mean? I simply loaded HiroToon, selected him, attemped to the apply one of the body textures and this is the result. It works for all body parts except the neck.
    And no, this is the original Hiro3/Hiro Toon.
    -MJ
  • mrposermrposer Posts: 1,134
    edited March 2014
    I just loaded Hirotoon and then tried several tintation skin colors (which one is it you have tried?)... I didn't have your problem. Hirotoon does have different geometry and uvs for the neck/head than regular Hiro.... same body so he can wear Hiro clothes but not Hiro textures. Not sure what is going wrong for you... maybe reinstall Hirotoon and the Tintation products and see if there was some fix since your original installs.
    Forgot to mention I used Daz Studio 4.6
    Post edited by mrposer on
    edited March 2014
    They are both fresh installs and the error occurs on all instances.
    -MJ
  • GhengisFarbGhengisFarb Posts: 173
    I've had this issue with Hiro Toon quite often even using the official hiro toon plug in for 3DU's texture converter that converts V3/M3/V4 etc textures to Hiro Toon or Aiko Toon heads it still screws up the neck. The only work around I've found is to take a snippet of the neck area and make a blank texture square of that area in a repeating tile format and using that for the neck, You'll still end up doing post work. I make all my comics with Hiro Toon and Aiko Toon STILL as there hasn't been any model come close to them for a comic look.
    Can i see some of work with HiroToon/AikoToon?
    -MJ
    edited October 2014
    Oh and the issue was fixed by re-downloading and re-installing HiroToon. There was a UV fixed since i last download and installed it.
    -MJ
    -MJ
    Here's Aiko Toon with Irina from Blackhearted (and Sir Guy).
    800 x 695 - 44K
    Here's a blow up of the chest and neck of Hiro Toon, the texture is Last Hiro I believe.
    800 x 704 - 48K
