Adding to Cart…
@isidorekeeghan Volume transmission as well as scattering is better tested with strong backlights on thin objects. For example a human ear.
In your settings you use a semi-white transmission with a quite high volume density. From a pbr point of view this means that the inner color of the volume is white and you only get the scattering color mixed with the translucency layer.
I'm not sure how this simplification may affect the sss "realism". But given that the chromatic mode seems buggy and not documented anything may happen.
edit. This is obvious but of course a 0.9 translucency is not good for hair and dust. The G8 makeups use a diffuse overlay over the translucency layer so this may work fine, but it is very likely that some adjustements may be needed to match the skin color. As an alternative a translucency map may be used in the weight channel.
edit. There's also something very odd with the natural spectral. From what I understand it should be something with slight color variations from faithful, while it seems to lose any light falloff at all, other than light energy. That's not good for studio lighting or any situation where some dramatic lighting is needed.
https://raytracing-docs.nvidia.com/iray/manual/concept/spectral_rendering.html
Below an example with your settings on G8F. First rgb, then faithful, then natural. Scene included.
edit. Just out of curiosity this is how she gets in cycles with the diffeomorphic plugin. That's of course similar to iray rgb since cycles doesn't support spectral rendering.
my latest attempts to get natural skin via glossiness/specular mode
I don't know .. faithful works just fine and it's spectral. It's natural alone that doesn't work. But I'm not a spectral expert I'd really like to hear from @RayDAnt, or anyone with some experience about this. I feel natural just doesn't work right. From a pbr point of view saying "you have to fit your lights" is nonsense no offence intended. Lights are just what they are they don't need to be fitted to a rendering method.
I reported that bug last September I think it was. I don't remember the response as most of my bug reports and feature requests are accepted and then get fixed consequently as peripheral changes of their other work and I don't get notified.
Also, if you ever change your DAZ 3D account email address you loose access to your old bug reports.
I've yet to see any feature request I've made been implemented but those things take time and for some of them a bit of work though not excessive work.
So you do agree it's a bug thank you I was just wondering. I submitted a bug report myself may be this helps them to get it better.
Well the iray docs tell exactly the opposite that faithful is more accurate while natural sacrifices some tints to be more "smooth". Then tristimulus to wavelenght conversion is not physically accurate by definition that's why we have different conversion intents. The truth is unless we get spectral data for materials and lights it's all a "best guess". Also I'm not using point lights but sphere lights that have photometric properties so they are intended to be physically correct, though using ies would be better. I agree that point lights are to be avoided. I also agree hdris seem to work fine so the bug is limited to scene lights.
Indeed there's something odd with photometric properties in daz studio since I need 15000 lumens in daz studio to make 1 watt in blender that's nonsense, it should be 15 lumens = 1 watt for incandescent bulbs. But that apart they seem to work fine.
edit. Of course until they fix the natural conversion I'd advise to stay with faithful.
What I noticed is that I had both Sun-Sky & photometric lights in my scene and that when I used the spectral the Sun-Sky stayed normal but all photometric lights seemed to stop working. I think that might be intentional and why they call it 'natural. 'Natural' because it works with the 'Natural' Sun-Sky lighting. I'm not sure though as they didn't tell me anything that I remember when I submitted the bug report.
I posted an example of both back in Sep/Oct 2019 in another thread but I'll never find that post.
@nonesuch00 Natural has nothing to do with the sun sky light. It is a method to convert rgb to wavelenghts. Again see the iray docs and/or google for "spectral rendering". I myself knew nothing about spectral until some days ago, but I have a strong technical background so luckily it's easy for me to find and understand tech notes.
Since the faithful conversion works fine with scene lights there's no reason why natural shouldn't. I mean if spectral wouldn't include scene lights then faithful wouldn't work as well.
As a photographer I totally agree with you, even the iphones have a portrait mode that creates a shallow dof.
@isidorekeeghan If you use a single light the test fails because you can't compare falloffs among different scene lights. Below you can see the natural conversion where I used a 10x energy factor in tone mapping. Falloffs are lost as it was already clear in the darker picture in my first post above. That is, increasing the light energy doesn't fix anything, apart it being wrong anyway.
That's the most I could get with a Daz character. That's Mousso character btw. Hes characters are very realistc overall. And from there is definetelly possible to improve a lot of things to make this more realistc. Like peach fuzz, textures etc. The volume SSS definitely play against realism, it's unintuitive, the values are very confusing. And there is a strange bug with the gamma of some textures of the characters skins.
The normal map of most characters doesn't really affect the final result like it should, the transmitance seems to wash all the detail. My computer crawls if I set subd more than 4, a good displacement is key to get a realistic result. All and all it's very possible, but very hard on daz studio.
If you check https://www.youtube.com/watch?v=s3fDXZ-c6u8. There is really nothing that daz have different, just the renderer. And he maskes it look realistc so easy, because Arnold is a lot simpler and predictible.
For what it's worth as far as 'realism' goes, I definately, out of all the Genesis 8, PA or DO, characters I've bought, think the shaders settings for Dain 8 are the best. They look good on Dain 8's materials images used with those shader settings and they look good applied to other characters whereby you keep the original images used in the skin materials but apply Dain 8's shader settings.
The other newest DO Pro Bundle characters, at least the ones the bundle was named after, likely use Dain 8's shader settings too. You'll know that's the case if a baby blue is one of the colors used in the surface settings. Dain't the newest Pro Bundle non-PA character I've bought so I ccan't check.
testing SSS and translucency response to different size
Iray!
There are a couple comments here with a similar thing and generally speaking, If your skin changes relative to other objects depending on lighting then that is a clue something is up with your skin settings.
Take this skin. Looks pretty good non?
Right up until shes strongly backlit and we realize shes actually a glowing jello monster disguised as a human!
Now this is obviously an extreme example as generally you arent rendering chaacters just backlit and nothing else, but even in less extreme versions, any lighting setup with backlighting the chest neck etc will be unnaturally brighter relative to a setup without backlighting, (not to mention you likely get some weird shadowing around the mouth and eyes)
Strong side lighting is also likely to create rudolph nose
This is basically my skin testing setup for the record.
even neutral lighting for over all look and tone
strongly backlit and raise transmitted distance as high as I can get it without the neck and torso starting to glow
rembrandty key light to make sure the nose doesn't glow and also that shadows on the skin soften. (see how the edhes of the shadows are red? also if you so a reder close up there isnt an ege at all but a transition)
this for me is a major key to making skin look soft and imo is subconsiously noticable in most lighting conditions, even though its rarely as distinct as here (its also great for a sort of painterly realism even if you dont hit photo real)
FWIW This is the area where I'm having the most difficulty matching what I see in reality. While where the nose and head cast relatively crisp shadows is close to matching reality, the crisp shadow terminator edge is very much not. This should be much softer, though I'm not sure is this is all down to sss or an effect of skin in reality being a much less smooth surface. If anyone has some suggestions for softening this up I am all ears
TLDR PSA: when setting up your skin settings don't do it with just even lighting
I'm using the same settings on the ears as the rest of her, I always edit as much as a unit as possible, so when editing sss i always select templates 1-4 (I even avoid having different spec settings on the lip from the rest of the face)
I'm using settings pretty close to yours, the render I'm currently working on has
spectral rendering on
Translucency strength 1.00
base colr effect: scatter and transmit intensity
Transmitted distance .025
transmitted color .98/.98/.98
Scattering distance .025
SSS color .95/.42/.18
SSS direction .3
also that first image you attaced is the perfect example of the problem thats currently annoying me. The shadow on the neck is spot on but the transition on the cheek is all janky. I'm trying to see if better vellus hair helps, but even if it does thats a pretty resource intensive solution currently edit: its definitely not just vellus, even without any vellus hair there is no sharp transition in blender
isidorekeeghan, I used your excellent settings and I believe my character came out near-photoreal in this HDRI scene. Thank you!
(larger attached)
Even with higher resolution you still get a certain amout of crisp termination that doesn't line up with what I've seen of reality
like on the cheekbones and jaw here theres a pretty sharp edge to the shadow which doesn't feel real to me (I probably should have turned down the light but it is a quick test render)
In this image I found on the interwebs the shadow cast by the nose and on the neck is fairly crisp so its clearly not a much bigger light source, but the falloff on the cheek and chin is distinctly softer
I definitely think some of it is vellus hair so I did a super quick test in blender because it renders faster
vellus hair affecting shadow termination
no vellus hair
I still think blender handles this a bit better than DS does in general
janky vellus that i didnt spend all tht much effort actually making look good
muuuch softer transition on the cheek and temple at this scale you cant even really see the individual strands (whichh is good as you don't in real life) just the softened transition
bad news the vellus hair here is made up of 300,000 strands. That is going to be signifigantly memory intensive in Iray
Yash, thanks for the tips.
Here another anoying thing, the hair should be blown out, but it's not.
You have to adjust every single asset to make it consitent.
And a more draamatic example. Very testy render. this is not "good" lghting and I put minimal effort into actually making the vellus hair realistic
but to my mind one of these looks infinitely closer to reality even with its flaws
No vellus
vellus
It's nice to see somebody finally post a picture again.
I agree with what isidorekeegan said she doesnt really seem to be fitting into the hdri for several reasons.
she seems overall a bit dar for the scene as isadorekeegan mentioned
the shadow she casts doesn't interact with the wall correctly (this could be fixed by using a matte object there are tutorials floating about)
perspective of the background is wonky relative to figure. the theoretical plane the figure is standing on seems to be a very different angle from that of the scenery, we're looking at the figure very straight on, but the table appears angled towards us the wall behind her even has a bit of a curve, which gives me flashbacks to the fist pair of glasses I ever owned which were slightly misaligned and turned the whole world expressionistic
The lighting doesnt seem to fully match up either, strangely enough for hdri, In particular if you compare her to the table she has very strong backlighting that is mostly absent from the table and the shadow she casts at her feet is signifigantly stronger than the shadow we can see the table leg casting. The table is also casting a shadow on the wall behind her but not on her legs
Most of this is honestly not stuff that people will actively notice unless they're looking for it but even without actively noticine something will still feel off
I honestly find HDRI where the background is close to the figure as it is here incredibly difficult to get looking good. HDRI are great for adding sky and distant trees, but really difficult to use as rooms to stick your characters in, at least in my experience
and i definitely need to fine tune this, because she looks a bit like a nice young menonnite lad right now, but now the actual Iray comparison
no vellus
vellus
Definitely starting to get that softer transition on the cheek , much more in line with how I look when I shine my phones flashlight on my face (well other than the fact that I definitely don't have cheekbones like that)
And while this is definitely just a test scene rather than a more real world lighting setup those harsh transitions are definitely something I've noticed, sunny hdris for instance which are pretty common, can easily create harsh shadow transitions like this
also irrelevant side note but blender is so much more efficient it hurts. Those blender renders finished before the iray ones even loaded fully and started.. but in ds I can reuse settings, strand hair, materials, etc so much more easily. So I'm not ready to abandon it quite yet
Thank you j cade and isidorekeeghan for your comments! I'm continually trying to improve, like all of us, so your feedback is invaluable.
Coincidentally, I'm going through tutorial courses now to learn Blender. Is it really very difficult to reuse settings and materials? You'd think this was something Blender would have in the bag!
My goal is to transition to Blender completely. I use DAZ to create comic images, so I hope that isn't a pipe dream....
As for light tests the method by @isidorekeeghan doesn't work with a simple three sphere lights setup. You may like to test your method too to see if it fits studio lights. Test scene included.
It is my advice to avoid natural and use faithful to get a correct light falloff.
https://www.daz3d.com/forums/discussion/comment/5743051/#Comment_5743051
