I can't find the Geometry List in the Figure Setup Pane
Hello Everybody,
             I wanted to learn how to rig in daz studio, I opened a tutorial, well, its written, I've provided the image below.
The tutorial says, in the Figure Setup Pane, right click anywhere on the geometry list, and click on "Add Geometry".
When I open my figure setup pane, there is no geometry list... I've provided that image down below too.... Its probably a silly question but, I'm new to daz, especially the rigging part, so I don't know how to add geometry such that it shows up in the geometry list of the figure setup pane.
This probably is because of the update and that the tutorial should be an older version, but even if so, How can I add geometry to the geometry list so that I can later transfer it into the relationships section of the figure setup pane?
Any help would be really appreciated, Thanks.
  • macleanmaclean Posts: 2,438
    What's happened is that you've hidden the left-hand pane, probably by accident. On the far left of the pane, next to Figure> Geometry> etc, there's a small rectangle to expand the pane. Click that and you should see the Geometry List pane. Right-click and select Add Geometry, choose your .obj file, then drag it onto Geometry (none) on the right.
  • Meruem3DMeruem3D Posts: 0
    @maclean
    Oh my God, I can't believe it was just hidden XD
    I looked for it like everywhere, never ever once thought that I would've hidden it by accident....
    I tried what you said and it worked...
    Thanks a lot Maclean, I really appreciate the help.
