Smooth Modifier and Dynamic Clothing (nesting issues)
jdavison67jdavison67 Posts: 690
In my playing around with both of these...I wish you could smooth modify against more than a single base...
Also I wish they dynamic clothing nesting worked better.
My problem is with a shirt tucked into pants that are tucked in boots.
I need the shirt to conform based on the body, but I also need the pants to conform based on the body, but not let the shirt poke through.
Again I need the pants to be aware of the body and the shirt, but not poke through the boots, which need to conform to the body and not conflict with the pants....ugh....
In the dynamic clothing, it seems to be aware which is draped over the other but does not eliminate poke through, which makes it worthless.
Applying the smooth modifier only runs you up against the above dilemma. All of these things need to be resolved for clean animated frames.
Until this is all resolved, any hope for a decent animated feature from Daz Studio is just silly.
Heres to holding our breath!
JD
  • bighbigh Posts: 8,147
    JD
    try - drape shirt
    then drape pants
    do not drape at same time
    then freeze
    then add boots
  • jdavison67jdavison67 Posts: 690
    how do I freeze?
    how do I freeze?
    click upper right hand box on the plugin - pick freeze
    you can't change any of the drape if you do freeze it
