Q Suit - dForce Error Preparing Object to Simulate
I just bought Q Suit, which says dForce - however any time I try to use dforce I get the error message "Error preparing Object to simulate".  This happens with trying to animate along timeline or to current frame.
I've added dforce modifier: dynamic surface to each clothing object.
What am I doing wrong?
  • barbultbarbult Posts: 26,391
    If the product is dForce, you shouldn't add a dForce Dynamic Surface yourself. The Q suit does not use dForce on very much of it. You are adding dForce to clothing mesh that was not designed for it and not intended to be simulated.
    Looks like only the shirt and tie use dforce, not very well I might add.  I'll give it another shot when I have more time to work with it .. if it still doesn't work right .. I'll be asking for a refund.
