"set studio key" shortcut
is there a way to make a keyboard shortcut for "set studio key" in animate2?
Post edited by abunezek on
f3 or window>workspace>Customize
Under the animate2 section there is an option to "Set Key". Highlight that option and rightclick. The menu will have an option to "Change Keyboard Shutcut".
Set to what ever you wish to do.
Be aware that ds now supports multi-key inputs, so you can use things like L+M+K, as opposed to the ctrl/shift/alt +key, but it can be a bit twitchy.
Ive tried this, it doesnt work, it doesnt add the key :(
yep, just tested this again and apparently that functionality is borked in 4.12.0.86.
support ticket time.
