March Madness Coupon, not valid?
BorgBoy7BorgBoy7 Posts: 102
I have earned up to $50.00 towards DAZ Originals in a single purchase.
However it is saying that the coupon code is not valid.
Am I just too early for the code to be active yet (8:00 AM Seattle Washington).
Also, if I go over $50.00 I just get charged the difference, right?
  • nemesis10nemesis10 Posts: 3,872
    Jessica dress is still in the "New" category so it doesn't apply...
  • BeeMKayBeeMKay Posts: 7,019
    edited March 2014
    IIt should work for the Freak 5, though.
    The code is broken. It has already been reported to DAZ, so they will fix it when they are in office. :-)
    Post edited by BeeMKay on
  • frank0314frank0314 Posts: 14,757
    Yes it has been reported to DAZ
    It has been fixed. The coupon applies now properly.
  • BorgBoy7BorgBoy7 Posts: 102
    Thanks for the help, the coupon is now working. :)
  • ArcoCreatesArcoCreates Posts: 35
    I am still getting a coupon not valid error. I have 4 items in my checkout, none of which have the green 'new' banner across the picture in the store, none of which are under $3 and all which have the Daz Originals logo.
    I have a request in to support, with supporting screenshots.
    What products are you trying
    Cargo Shorts and Tee for Genesis 2 Male(s)
    Cargo Shorts Textures
    Internship Outfit for Genesis 2 Male(s)
    Internship Outfit Textures
  • anikadanikad Posts: 1,919
    There have been issues before with items that have just come out of their 60 days new item phase and coupons. You might want to raise a support ticket or try some other items. Those items look to be just past the 60 day mark.
  • ScoopeyScoopey Posts: 191
    I started a near identical thread in Members only.
    My voucher was not working but now it is...seems someone kicked the web editor because a wrong bundle item was showing up as punchworthy. That has been swapped at the same time the voucher seemed to start working...
  • Jay VersluisJay Versluis Posts: 268
    Sorry to warm this thread up again, but I've had the same problem today (May 30th 2014).
  • Richard HaseltineRichard Haseltine Posts: 108,920
    What code did you enter, and what did you use it on?
    The Code was 05-14PlatClub and I used it on the items below. I've sent an email to the support team, just want to make sure the system is working fine.
    1011 x 745 - 121K
  • RenpatsuRenpatsu Posts: 828
    The only DAZ original item in that order appears to be the moon lander and that one is a free item with platinum club. It dos not work on non-DAZ originals, so I'd expect it to fail there.
    Coupons are valid for DAZ Original, non-Platinum Club, non-resell items. Coupons may not be used to purchase third-party Published products (often called "brokered" products).
    Ha, I never knew that - I had always assumed it's off everything. Thanks for clearing that up!
