Face morph no found
hello there friends,
I am confused with need some clearity of the product please help me. i am using Daz studio 4.6 pro and i have seen that only the "Genesis 2 Base male and female" can be morph with morph bundle but when not he basic male.
"Basic Male" is a morph of the Genesis figure. Genesis and Genesis 2 Male are separate figures and require separate morphs. If you bought the Genesis 2 Male Morphs Bundle you can use these morphs on any Genesis 2 Male character. The morphs for the Genesis figure are sold separately.
Here's some more information on the various figures and generations of figures.
well thank you my friend you post give me lost of information. thank you again
No problem...happy to help. :)
Hello There Scott-Livingston,
A more help please
I tried to installed a "Genesis Head morph Resource kit 2" a Warning message Flash every time. Following is the message.
"Genesis Head morph Resource kit 2 is and add-on for "Genesis" and they must be installed in the same local. please choose a different install location or install the required product first."
Suggest please.
Are you using the Install Manager to install this product? Have you installed "Genesis Starter Essentials," and if so, did you use the Install Manager to install that?
For best results, I recommend using the Install Manager and having it install content to the default location. It's possible to do it manually instead, but in that case you need to make sure you're installing to an appropriate location, and you need to make sure that DAZ Studio knows where you've installed it to. If that's what you're having trouble with, let me know and I'll try to assist...but really I'd suggest using the Install Manager instead.
hello there
yes i have already installed the "Genesis starter essentials " but i didn't want to go with install Manager hope you got the hint for why. Is it possible to installed manually?
Thank you
To what location did you install Genesis Starter Essentials? You can find the default install paths here: https://helpdaz.zendesk.com/entries/20621026-Content-Install-Path-for-DAZ-Studio-4
You'll need to download and unpack the zip file and then look inside it to see what folders are there. If you see folders like "Data," "People," "Runtime," etc., you'll need to merge them with the folders of the same names that exist within your content location ("My Library" or whatever it's called on your system).
Here's a link to more information on the manual installation process: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/installing_software_plugins_and_content/tutorials/basiccontentinstall/start
That installer will be outdated, you should download the zip from your Product Library.
dear fixmypcmike,
which zip are you saying about. will you please define details.
thank you
"Genesis Head Morph Resource Kit 2" -- from the error message you're getting it sounds like you are installing with an .exe file. That will be out-of-date, as content is now in .zip files.
dear fixmypcmike,
Yes this is exactly what is happing. i am trying to install an .exe file. what is you suggestion for this.
Thank you
Go to your Product Library and download the current version, which will be a .zip
hello fixmypcmike,
Thank you for your help most of them were installed i think i can work out as needed. will post for more help to you.
