send to center "stage"
Some props are designed with a specific location, for the upper level of a house or somewhere far away in the background. XYZ parameters are at zero
Is there a magic button somewhere to reset the integrated location even if the prop X Y Z sliders are at zero ?
thanks
Yves
Post edited by golem841 on
No, but you can do it with the Align pane and a cube.
Create a cube (or any primitive), any size that's convenient. It will be at the center of the universe (or stage). Open the Align pane, and in the Scene pane select the cube first, then your prop. Now all you need to do it set the transforms you want and apply them.
If you want to resave an object in its new position, you can use the Parameters menu to memorise the translations, which will become the new default for that object, then save it.
Thanks a lot !
