goz not showing daz 4.6
crappyaccount999crappyaccount999 Posts: 0
help me please i have installed goz for daz 4.6 pro via install manager it is not showing up in file menu
plz reply quick
  • jaxprogjaxprog Posts: 312
    I have never had any positive results using DIMM when installing the GoZ bridge or the one for Photoshop. What I had to do to get mine to work was do a manual install.
    First using DIMM to uninstall your GoZ and delete the package
    Go to your account
    Go to your product library
    Filter to find Goz
    Use the blue download button and an install it manually.
    So you will need to manually navigate via windows explorer to find the downloaded files and execute its setup.
    796 x 226 - 40K
  • crappyaccount999crappyaccount999 Posts: 0
    Go to your account
    Filter to find Goz
    i tried but no luck still no "send to zbrush is showing up"
  • JaderailJaderail Posts: 0
    There is a known issue. If you ever had the Zbrush Demo installed it causes a conflict with the Bridge. The only way around it I think is to install the Full Zbrush and then the GoZ bridge by hand.
    i have full zbrush installed zbrush 4 r6 p2 but still no "send to zbrush option showing"
    I'm not familiar with ZBrush as a user. I was simply repeating what I have read. If the Demo was ever installed it caused errors was All I know. I do know that many have got it to work but I'm not sure what was needed to do so.
    only once i was able to see and use send to zbrush option
    but after i formatted my pc and reinstalled daz 4.6 i installed all daz goz plugin but still no luck
    edited March 2014
    Well I know this much. First the Full ZBrush must be installed (yours is) and you must use the GoZ bridge file that matches the version of DAZ Studio in two ways. First the GoZ file MUST be for the same version number of DAZ Studio you have installed. Example (GoZ for DS4.5.2.39 will not work in DS4.6.2.118) your GoZ file must match the DS version number and the Bit so 64Bit or 32Bit also matters. If all that is correct I have no information on what is needed to get it to function. Try looking in the Nuts & Bolts Forums and the DAZ Studio Discussion Forum for posts on the GoZ topic.
    Post edited by Jaderail on
    thanks Jaderail i will try :-)
    edited March 2014
    This is one thing I noticed last night when I was trying to resolve my CMS database issue. When Daz Studio went to version .2 it knocked me GoZ bridge in Daz Studio out. I had not upgraded my Daz Studio to version .2 yet at that time but when I did last night it put Goz back in automatically via DIMM which never worked in the past when trying to install GoZ bridge. So I guess Daz has it corrected any installation problems.
    The main issues with installing GoZ is...
    1) Daz Studio Version is compatible with GoZ version. In your product library for Daz Studio you will see all the little packages you can install. GoZ is one of them and that should be the latest one.
    2) In your DIM make sure you tell it the path of your zBrush app. Screen shot attached for this.
    742 x 520 - 44K
    Post edited by jaxprog on
    Thanks it worked it was a daz 4.6.0 problem updating to .2 sold issue
    thanks really thanks lvu :-):-)
    That is a known thing, with every update to DAZ Studio the GoZ file listed is for the new version only. It is up to the user to Download and keep the older plugin versions for the older DAZ Studio versions. Only the new updated plugins list in DIM or Products once they are released. I now keep back up copies of all my stuff just in case I need to do a Roll Back for any reason. So get your working Plugins Now before a new version goes live, get all the files you can for the version your now running and then you can roll back fully at a later date if needed.
