G8F eyelashes default length
TomCatOliver
I posted this in the Technical Help forum, but perhaps not many people look there - not many views and no replies, so I've copied my question over to here. Really only needs a "yes, this is normal", or "no, something's wrong" sort of reply...
I just wanted to check what the correct default settings are for the G8 (male and female) eyelashes. When I load the base G8s, or even the G8 Dev Load figure which loads without eyelashes, the Eyelashes Upper Length, Lower Length and Eyelashes Curl morphs are all at 100%. I was wondering if that's right, or if something has caused them to be set that way.
The reason I ask is because when viewed slightly turned to one side, the lashes just seemed to be too long - considering thoat some characters have morphs to make them even longer.
There's nothing suspicious turned on under "currently used" or "hidden". I don't want to spend ages trying to figure out what might be wrong if the default values are actually correct, and I just never really noticed before how long the lashes are. To be fair, I don't do very many close ups, so I could have simply not noticed for the past 3 years...
That is correct default are set to 100% :)
Thanks for confirming that.
