Using a HD figure?
BHawk
Sorry for the beginner question, but how do I use an HD add on to a character?
Christian 8 with Christian 8 HD add on as an example.
BHawk
Some figures also have an HD morph slider that needs to be cranked up.
Thank you for the replies!
#1 Excellent point! I didn't even think of that.
#2 subdv? Per the porduct page -Viewport subdivision must be turned on - is that parameters mesh resolution?
#3 Another excellent point.
#4 Shhh
And I was thinking they were morphs and I think I found them there. Thank you much!
Select your figure and Go to the Parameters Tab. In General, select Mesh Resolution which for the default HD addons is 4... if it is less than that, you don't really see much HD effect.
Keep in mind every step up in subD quadruples the figures geometry. SubD 4 is doable for me but 5 usually causes scenes to drop to CPU.
