Trying out Daz
Edd_ weavo-1Edd_ weavo-1 Posts: 38
edited December 1969 in Art Studio
With this image, how do I correct the lighting with this image I'm doing?
  • Richard HaseltineRichard Haseltine Posts: 111,475
    You probably want to lower the Reflection Strength, or remove the reflection maps, or both on the clothing. I'm not sure on the ground - is that from a light or is the ground loading like that with no lights added? What effect are you aiming for?
  • Dream CutterDream Cutter Posts: 1,224
    The ground material you are using is large scale, not great for close ups, however will be fine at altitude. Try positioning so the horizon is lower. Do you want the plane to have a ground shadow?
