emotion skirt
Ruphuss
first I like this outfit
but...
why is there a (...) in the skirt
(you English speaking people how do you call that ?)
Ruphuss
but...
I dunno, an indentation & distortion?
What morphs do you have dialled in to G2F? Looks an like auto-fit problem, I'm guessing it doesn't look like that on a plain Genesis 2.
And if the item supports it, have you tried increasing the smoothing iterations some? set it to about 5-10. (Parameters Tab /General /Mesh Smoothing)
Auto fit doesn't like skirts very much.
this is out of the box
and though I don't like to rely on smoothing I tried that but its not better then
in the promos theres no issue like that
but I used GF2 not Josie
Compatible 3D Figures:Genesis 2 Female
Which out fit is it? can you give us link please? - Edit: never mind it emotion skirt as per the topic title herp derp.
we call it a camel toe
http://www.daz3d.com/emotions-for-teen-josie
that term I know for something I cant post here because of familyfriendlestsiteoftheworld
I wouldn't call it that, a camel toe is a lot more.. ahem.... 'graphic' than that. :)
Considering its on sale item ill buy it and take a look.
Tested it, well its being sold for teen Josie. and on teen Josie it looks perfect. I get the indentation if I un-dial teen Josie.
In a nutshell, it works for the for the character its made for (for me at least), in the data folder the skirt also has custom morphs for V6, G6 and Gia but the indent is still present on those as it is Standard G2F. So I'm not really sure how the vendor went about it, but it seems like the indent was overlooked.
Although I can get the indent as you have shown, I cant replicate the stretching on the hem in your screen shot. Did you dial in Teen Josie before or after you fit the skirt to G2F?
I don't have Josie and its not required
Fair enough, maybe drop the vendor a line (PM) and point them tot this thread.... there could be something we missed.
If you are getting that on a conform/fit to out of the box then I'd guess the problem is the rigging. Looks like the part of skirt that falls below the hip is rigged to the thighs.
Q and A overlooking this in the base morph and the other custom morphs is not a good thing.
It would be best to file a bug report, by opening a support ticket for technical Support, so that it can be looked into.
In the initial picture, it looks to me that the front of the skirt is draped over thighs larger than they are in the pic. Maybe the morph is trying to make the indentation so as to correct that drape in the front.
the skirt has the gap(now I've found the word) even with fit to none
I made a quick morph with a dformer to pull out that crotch dent. I'm sure the vendor could do a better fix, though. Have you written a support ticket yet? I will do it if you don't want to, Just let me know. (I write lots of bug reports on products, so I'm used to it. I think DAZ is sick of me. %-P)
By the way, if you use the skirt on a character like Danika, the hem in the center of the skirt gets jagged. I found that turning off the Danika genital morph fixes that. I don't need that anyway, when it is covered by the skirt, so turning it off is no problem for me.
These images are G2F with the out-of-box skirt and the skirt with my morph applied at 100%.
thx barbult
I'm just a bit tired of all the workarounds
if you are so kind writing the ticket
I think you can explain better then I can
I have submitted the bug report.
I have the artist looking at the skirt.
Jen, I have never seen such a lightning fast response from the DAZ team. Great! Thanks!
It's been a few weeks now. Is there a fix in the works?
In the works just not done yet. The artist is at the moment working on a project and has promised to get to the fix asap
Thanks. Good to know it is in the works and not forgotten or dismissed.
...I had a similar issue (well sort of ) with the Saucey Overalls in that there was an outward "bump" in the middle of the shirt and upper panel of the overalls when I tried to use them on a small breasted character, Apparently this was done to eliminate the "saran wrap" effect on the breasts, however did not take into account someone like me dialing down breast size to more petite levels. At first I had to use DFormers to minimise the effect but a new morph was later provided that fixed it.
Has this been fixed yet? Is it worth re downloading?
Cheers.
Yes a morph has been added to remove the divot.
Mark it in your calenders. This was the day Crotch Dent became the new slang term for vagina.
Thanks for the reply.
I'll give the golf morph a try. ;-P
or divot
I am still looking for a camel ...
